Offroad & 4x4
4-linking the Bronco
Old Feb 4, 2005 | 05:41 PM
th0mpson182's Avatar
th0mpson182
I have some big plans for my Bronco this upcoming summer. Right now it has a 6" Superlift. 3" Black Diamond Body Lift. 15x12 Rims and 44" TSL's. I have a Sterling 10.25" rear end and a Dana 44 front end (SAS last summer). Please no comment on the 44's on a Dana 44. My truck is a daily driver street truck that I just keep nice and enjoy having. The 44 has held up fine on the street and was worth the $150 as opposed to the $1500 to rebuild and have a D60. I am wondering if anyone knows where I can maybe get some coilovers? I want to try and do a 4-link with coilovers front and rear. Are there any 4-link kits for my truck or maybe one that i can fab to my truck. I think Fabritech makes one but I've told that it's Fabricrap for what it costs. Anything out there cheaper than King Coilovers? If not is there anyway I could do coils front and rear? Could I set up the rear with two heimed radius arms and a track bar like the front? Just ideas... Anyone got any thoughts?
Old Feb 4, 2005 | 06:03 PM
monsterbaby's Avatar
monsterbaby
there are a couple of threads on 4 links in the past day but if you are not wanting to go to that extreme, you can build the ladder bar with coils like I did for the rear I used 6" lift coils out of a bronco II, and the coil buckets from the front of a 92 exploder, and built my own ladder bars using tractor top link joints from the tractor parts store. here a link to a pick of it when it was still in the works.
https://www.ford-trucks.com/user_gal...oid=38648&.jpg
Old Feb 4, 2005 | 06:13 PM
th0mpson182
that look str8 man and also in my price range, one question? Am I missing them or are there no shocks back there? any particular reason if there aren't?
Old Feb 4, 2005 | 06:17 PM
monsterbaby
no like I said that picture was while it was still in the works, I should go out and take another pic of it as it is now with the shocks and drive shaft, and all in it. but I will tell you the shocks are set up with the top in the hole on the coil buckets, and I built a bracket for the bottom.
Old Feb 4, 2005 | 06:33 PM
monsterbaby
here try this you can get a better view of what it looks like when the truck is finished
https://www.ford-trucks.com/user_gal...oid=45368&.jpg
Old Feb 4, 2005 | 10:54 PM
ivanribic's Avatar
ivanribic
Don't mean to sound like an *** but why do you want to 4 link a truck that only sees pavement anyway? If you've already got a lift that clears your tires I can't see the point . . . but maybe that's just me.
Fox and plenty of other companies make coil overs too if you want to go that bling.
Old Feb 5, 2005 | 09:08 AM
th0mpson182
I'm just something I want to do, Not many Bronco's have coils front and rear plus it'd be easy to lift up a little more like I want with coils front and rear.
