S. California Chapter Join Chapter, Leader:
1999 Ford SD Electrical. Interior Lights
Old Feb 4, 2005 | 05:31 PM
ItsTunaTime's Avatar
ItsTunaTime
I have a problem. When I drive, My interior lights keep going off & on. You can hear the relay kicking off & on. The door ajar idiot light stays on all the time. It seems only to happen when I have a passenger. I took the inner passenger door panel off to see if there is a stuck open door button switch. There is none. I followed the wiring loom to the door lock & there is 2 plug in connectors. 1 is for the electrical door locks. The other I do not know. I have 66500 miles on it & it seemed to start around 60000. ( after the warranty ended.) Also, the interior light goes on when you are stepping on the brakes to slow down. Electrical gremlin I guess. What I have is a 1999 F250 XLT crew cab short bed with a V10 auto.
Old Feb 5, 2005 | 06:57 AM
edsf100's Avatar
edsf100
Welcome to FTE and the So Cal Chapter. Please check out our local meeting times. For a question like this try the
https://www.ford-trucks.com/forums/f...splay.php?f=62
This will get you to the guys dealing with electrical problems. Pretty sharp bunch of guys. Nice to have you around.
Old Mar 17, 2006 | 09:27 PM
cheerwineman's Avatar
cheerwineman
I Have The Exact Problem. Dont Understand Why It Happens When You Hit Brakes. Also Have A Problem With Park Lights Not Going Off With Other Lights. Please Help
Old Mar 19, 2006 | 09:52 PM
73Fastbackv10's Avatar
73Fastbackv10
Spray the door latch with some wd-40.
Old Jun 11, 2006 | 01:10 AM
69cruiser's Avatar
69cruiser
wd-40 is the trick thats what fixed my problem on comes back after it rains spray it and it goes away
