Mudding and engines Q's.
Also, I'm curious as to what the differences are between the 351W's, M's, and C's.
I wanna put another engine in my truck, and was thinking about keeping my 351W, and just stroking/turboing it.
I've been debating that same situation for my Bronco. A 427W is certainly doable, but if I can just throw a 572 in there...I just like hearing the small blocks scream...
As to your other questions, the 351M/400 are essentially identical except for bore. The 351M and 351C are part of the 335-series. The M has a 385-series bellhousing, and the C has a small block bellhousing. The 351W is 289-based and shares the same bellhousing as the 260, 289, and 302. The windsor has a lot more cheaper performance do-dads, thanks to it being based on the 302 and 289. The modified and clevelands have them too, but they're harder to find and more pricy, and it's also harder to find good engine builders who know these two engine intimately, whereas nearly any rebuilder has done a 302, so a 351W is more easily related to.
As to you question of differences well there are plenty but the c, and m are both of the 335 series engine family, which has the canted valve heads. the windsor uses a wedge head, and has a 9.5" deck, the cleve is 9.2, and the M is 10.? and used the big block bell housing. they all have a 3.5" stroke, and a 4.00" bore
but as far as you question as to what is best that all depends on you, and what your doing with it, how big of tires your running, is it mostly a street vehicle, or a competition only vehicle ther eare alot of variable in answering that question
Or, you could try turbocharging the engine, that would give it some oomph.
anyways id just stick with what you got because if you change out the motor you will then have to change out tranny transfer case rear end etc etcbasicly stick with the 351w put some go fast parts on it stroke it hell turbo nos super it and go have fun
