headers or stock?
Old Feb 4, 2005 | 01:26 PM
Wylieford05's Avatar
Wylieford05
Exclamation headers or stock?
i have a 94' f150 w/ a 351w. i have full length headers and it sounds pretty good. the problem is the egr tube wont mount to the new headers and it throws my check engine light with no tube. i could use some ideas on how to install the tube into the new headers and where on the header should it mount?
Old Feb 4, 2005 | 03:57 PM
moose94's Avatar
moose94
One suggestion would be to drill and tap a nice hole for the egr tube in either the header itself (not really great that way) or the exhaust tubing. Adapt a fitting to fit on the egr pipe and securly fit the two together. That's a non-permanent method of course. If you wanted to get a shop to weld it in. I just left mine out underneath in my 302. I didn't care. Nothing bad has happened so far.
