Power brake conversion
Old Feb 4, 2005 | 11:07 AM
Icicle's Avatar
Icicle
is converting my brakes on my 73 f100 to power brakes as simple as buying a Master cylinder with a brake booster or is it more complicated than that
Old Feb 4, 2005 | 02:33 PM
olfordsnstone's Avatar
olfordsnstone
When I did my 74 F250 4x4, I had to change my porportioner valve, master cyl, booster, and front end. I also had to acquire a couple of thread adapters (Napa Auto Pts) to use to connect the brake lines to the master cyl. Also, a double flare tool to install new fittings on the ends of the lines at the front wheels. A donor truck would help with alot of this if one is available. The F100 may not entail as much too.
It wasn't that bad of a job, just time consuming to make things all fit together. Like I said though, yours might be an easier job.
Old Feb 4, 2005 | 02:45 PM
GeneStoner's Avatar
GeneStoner
Check it:
https://www.ford-trucks.com/article/...d_Broncos.html
Old Feb 4, 2005 | 03:12 PM
Icicle's Avatar
Icicle
interesting read Gene....
Thanks for the advice and links guys.
