STARTING PROBLEM, E-150, 1985
Old Apr 20, 2002 | 12:26 PM
haraks's Avatar
haraks
I have trouble with starting my E150 - 1985 Ford Van. It was working fine and suddenly will not start. I checked there is no spark when I lifted the high tension cable from the center of distributer and tested with a spark plug. I replaced the ignition module mounted at bottom side of distributer and replugged 6 pin socket to it and twisted wires of single pin connector as it was broken. still no spark. can you guide me what can I check or replace the Coil?
Old Apr 20, 2002 | 10:33 PM
Varnish's Avatar
Varnish
trevisM
Jan 11, 2015 02:24 PM
pwitk
Jan 15, 2014 10:01 PM
g_k50
1978 - 1996 Big Bronco
21
Oct 11, 2008 07:48 PM
anthtony1967
Dec 6, 2006 04:48 PM
will2526
Sep 23, 2006 05:25 PM
