Problems with Idle
Old Feb 4, 2005 | 10:17 AM
yellowducman's Avatar
yellowducman
Problems with Idle
I have a 2004 Excursion with the 6.0. The problem I have is sometimes the idle goes up and down and the motor shakes really bad. Its been to the dealer 3 times to upgrade the CPU and still does it. Has anybody else have this problem Thanks.
Old Feb 4, 2005 | 10:52 AM
fito1411's Avatar
fito1411
I had the same problem in my 03 6.0. it was the oil. I was overfilling it.It turns out that when you drain the oil only 13.5 quarts come out. when you put 15 back in it overfills and the oil foams.The dipstick should only be wet on the bottom quarter of the fill mark... Try that,it worked for me.
Old Feb 4, 2005 | 06:16 PM
Bushwhacker's Avatar
Bushwhacker
Another good reason to have the Fumoto drain valve! If you are to full just crack the valve out and drain a quart or however much. Close the valve and wallah! No runs or drips or errors!
Old Feb 4, 2005 | 10:27 PM
SBV45's Avatar
SBV45
Check the ....Tech Folder..... above. Read the section on changing oil and filter. The oil affecting the idle has been around since the intro of the 6.0. Discussed here first on FTE.
