Sponsored by: Kumho
Rear Leaf Springs
Old Feb 3, 2005 | 09:04 PM
turbine99's Avatar
turbine99
Rear Leaf Springs
Does anyone have some tips on how to remove the bolts out of the bushings on rear leaf springs? The nuts are off but the springs won't budge. I'm trying to replace a busted set on a 1988 F150 but can't get the old set off.
Thanks
Old Feb 3, 2005 | 09:27 PM
ivanribic's Avatar
ivanribic
They tend to get rusted into the bushing sleeve. If you have an air impact it will break them loose and you can get them spinning well so that they'll slide out. Otherwise you'll have to get busy with a penetrating lube and carefully pound the bolt out from the back. If you do this be careful not to munch the threads on the end.
Outlaw56
Feb 4, 2017 09:40 AM
408 Torquer
Aug 29, 2016 07:19 PM
Pappawheely
WTB - Parts & other
Apr 16, 2016 05:14 PM
EWHOLTZCLAW
Mar 28, 2012 03:11 PM
geoaigel
Dec 18, 2002 06:42 PM
