1978 - 1996 Big Bronco
Shaking violently when breaking
Old Feb 3, 2005 | 07:22 PM
93bronc84's Avatar
93bronc84
Smile Shaking violently when breaking
When I break my truck shakes like crazy, I was reading something that said engaged auto hubs might cause this. It seems to be intermittent so this is why I am leaning more towards the hubs being the problem. (good thing I have WARNs on the way!) I had my truck in the dealership 2 months ago and had a brake inspection with high marks so I wouldnt see why they would be causing it. also it seems worse at higher speeds.
Hope I gave enough info for some help TIA
Old Feb 3, 2005 | 07:50 PM
MatthewC's Avatar
MatthewC
I would check the simple things first, Balancing, tire pressure. Also, even though your brakes may be good, you could also have a warped rotor which would cause shaking as well.
-Matt
Old Feb 3, 2005 | 08:16 PM
poffutt's Avatar
poffutt
Take the truck to a professional break shop. They usualy always offer a free break check. have them check for wheel bearings, ball joints and tie rods. This will help pinpoint the problem.
Old Feb 4, 2005 | 01:35 AM
kameronth's Avatar
kameronth
I also think it could be a warped rotor, but if that was the case you would think that the dealership would have figured it out. Do you torque your lug nuts to the right specs, if not it will cause your rotors to warp.
Old Feb 4, 2005 | 12:42 PM
93bronc84's Avatar
93bronc84
I dont remove my tires much but I am sure the shops that have dont pay much attention to that. Also, the free break inspection will check for warping?
Old Feb 4, 2005 | 04:27 PM
92EBnTX's Avatar
92EBnTX
My '92 shook badly when I applied the brakes (it is "brakes" BTW. "Breaks" are fractures... LOL) before I bought new tires. The belts in the old ones started seperating, causing lumps to pop up on the treads. These lumps are easy to spot.
