1978 - 1996 Big Bronco
Correct Fuel Pressure
Old Feb 3, 2005 | 06:33 PM
rudder9's Avatar
rudder9
Question Correct Fuel Pressure
I Have A 95 Bronco W/ A 302. This Past Summer I Did A Build Up On Her.i Added A Fms E-303 Cam, A Pro-m 80 Mm Maf Sensor, An Edelbrock Intake,a Bbk Twin 56mm T.b ,24lb Injectors A Complete Exhaust System ,a Set Of Pulleys And A Whole Msd Ignition System. I Have An Adj. Regulator. I Have The Fuel Set At 38-39 Lbs. Is This Enough? I Haven't Been Able To Get A Straight Answer. Sometimes She Feels Alittle Sluggish As If She Wasn't Getting Enough Fuel.
Old Feb 4, 2005 | 05:16 AM
Torque1st's Avatar
Torque1st
Posting Legend
Get yourself an A/F mixture meter and install it. A 302 will have a hard time producing enough torque to push a full size Bronco around. You may need to drop the gears or go with a higher stall converter if you have an automatic.
Old Feb 4, 2005 | 11:40 AM
tHeCoS's Avatar
tHeCoS
here's my opinion, I too have a 302...i think the combination you have may not see nite and day difference unless you put a big stroker...347? You may also think about maybe you're giving her too much fuel (A/F mixture meter.... ..) The 302 came with 19 lbs injectors. Check your compression and also look into the Torque Converter too!
