Hard to steer please help!!
Old Feb 3, 2005 | 01:51 PM
liljase's Avatar
liljase
I have an 86 F150,4X4,302 fuel injected,my problem is the truck steers fine when driving but if when I am trying to turn the wheel to get out of a parking spot or start off it is very hard to turn.If I am sitting still and try to turn the wheel it barely wants to turn but as I start to move it gets easier.Any ideas what it could be? The power steering fluid is full,I am wondering if it is the steering gear box,please help.Thanks for any info in advance.
Old Feb 3, 2005 | 05:09 PM
mdstud's Avatar
mdstud
Could be the power steering pump, How does the belt look? Have someone turn the steering wheel all the way to the lock and watch to see if the pulley stops spinning on the pump, if it does you need either a new belt of the tension needs adjusting.
Old Feb 5, 2005 | 02:08 PM
liljase's Avatar
liljase
The belt and the tension are good.Any way to rule out the gear box or is it safe to say it is the pump.
Old Feb 5, 2005 | 06:52 PM
mdstud's Avatar
mdstud
I think i remember seeing somewhere a way to measure the pressure from a power steering pump, lemme see if I can dig it up.
Old Feb 5, 2005 | 06:56 PM
Boss50's Avatar
Boss50
My steering went dead the other day and I thought it was a loose belt. Turns out the bracket busted off the front of the engine...Do you have oversized tires? Those will wear a pump out faster.
Old Feb 5, 2005 | 07:00 PM
Mr. Finch's Avatar
Mr. Finch
I dought it is the gear box, because from my understanding the pump is the actual power supply, and if it was the box, you would probably have more problems steering other than it just stiffening. away to check if the pump is even doing anything is to detach the lines from the gear box, and put them both in a small seperate buckets half less than half filled with fluid, then start the truck, have someone turn the wheel and see if the fluid from one bucket moves to the other. You could do this test by having one bucket of fluid, and another empty bucket, and try it with one line in the bucket of fluid and the other in the empty bucket and then switch the 2 if nothing happens but it may take longer. This test will only tell you if the pump is doing anything, it won't tell you if the pump has the right pressure, so if nothing happens, then you have a bad pump, if fluid moves than either you have another problem like a clogged line, or your pump is too weak.
Old Feb 5, 2005 | 11:00 PM
one-shot24's Avatar
one-shot24
i just had the same problem on a resent thread. pretty much same setup. go ahead and get someone to turn the wheel while you look at the pully. thats the only way I actually saw the problem i was having. outside of the pump being wore out, the belt was intirely to loose. even though i thought i tightened the $#!* out of it. the guys that helped me deserve thanks. i dont have the problem your haveing any more along with being able to keep a belt on track.just like your it drove fine. only when turning with out giving it gas or when i bared down on it in a turn is when i had probs.
Old Feb 10, 2005 | 07:59 AM
alcan60283's Avatar
alcan60283
You might also want to try bringing up the idle speed a little bit. This will turn the pump faster, giving you better pressure to the box. It'll also make your alternator charge better, and the water pump will flow more water ! Try bumping it up about 50-100 rpm and see what happens.
Old Feb 10, 2005 | 09:40 AM
felixr's Avatar
felixr
sorry to jack this thread but how would you bring up the idle speed? through the timing? or adjusting the throttle cable?
Old Feb 10, 2005 | 09:54 AM
mdstud's Avatar
mdstud
Well I don't know of any way to raise the idle speed except reprogramming.
Old Feb 10, 2005 | 06:30 PM
Boss50's Avatar
Boss50
You adjust the idle by turning the idle screw on the carb.
Old Feb 10, 2005 | 06:56 PM
mdstud's Avatar
mdstud
Ya but this thread is about a fuel injected vehicle, no carb.
Old Feb 10, 2005 | 07:45 PM
1980_f_100's Avatar
1980_f_100
well since it is fuelinjected i wounder if it is one of fords great ideas with the adjustable rods in the steeringbox, i'm guessing it would be, if it is, take off the jam nut and adjust the rod, it helps w/ handleing and takes play outta the wheel, let me know if you want more info
Old Feb 11, 2005 | 07:28 AM
Boss50's Avatar
Boss50
Oops, my bad. I didn't read everything. By box has a screw that you can loosen or tighten to adjust how hard or easy it is to turn.
Old Apr 14, 2005 | 07:16 PM
Green Meanie 85's Avatar
Green Meanie 85
Smile
I had a 79 F-150 4x4 once that had a problem something like that,it would turn to the left ok but,not to the right. After i rebuilt the box,new pump,and everything else turned out believe it or not the axle u-joints were froze tighter than he11! After i put those in i could steer it with one finger!
