axle code?
Old Apr 25, 2002 | 04:26 PM
scott9320's Avatar
scott9320
axle code?
I've got an 85 f-250 4x4 and I would like to know what the axle code 73 is.
thanks in advance,
scott
Old Apr 25, 2002 | 04:34 PM
HotWhlz85's Avatar
HotWhlz85
axle code?
The 85 owner's manual shows it to be a Dana 3.54.
Ron
Old Apr 25, 2002 | 08:20 PM
scott9320's Avatar
scott9320
axle code?
can you tell me which dana it is and what axle do i have in the front. is it a dana 44 or 50?
Old Apr 26, 2002 | 07:28 AM
HotWhlz85's Avatar
HotWhlz85
axle code?
Sorry, the owner's manual only says Dana. Maybe some of the other guys here might know.
Old Apr 26, 2002 | 08:46 PM
kspilkinton's Avatar
kspilkinton
axle code?
[updated:LAST EDITED ON 26-Apr-02 AT 09:53 PM (EST)]Since it's a 3/4 ton, it's more than likely a Dana 50 if it's a TTB up front. The rear would be a Dana 61. If you have a solid front axle you'd have the Dana 60 up front. Also the tag on the differentials should give some reference. If I remember correctly, the Dana 50 TTB is essentially a beefier version of the 44 with 8 lug hubs. To make it even more confusing the 44 could have also shouwn up on this truck....whooo...
-Kerry
Old Apr 26, 2002 | 08:53 PM
TJ82f150's Avatar
TJ82f150
axle code?
