Cold Starting
Old Feb 3, 2005 | 09:10 AM
AJ21's Avatar
AJ21
Cold Starting
I just replaced my glow plugs on my 99 powerstroke, but it still has a hard time starting when it's cold. Once it's warm then it will start right up all day. Only when it sits overnight does it struggle. Any Ideas?
Thanks!
AJ
Old Feb 3, 2005 | 10:15 AM
Technitom's Avatar
Technitom
Veteran: Navy
welcome to the forum.
do a search in this forum... go advanced search, pick titles and type in either cold or hard... its been covered many times... good luck
Old Feb 3, 2005 | 12:51 PM
slaymdr's Avatar
slaymdr
Replace your GPR glow plug relay. Easy job. Mine just did the same thing. I replaced the glow plugs and it still didn't start. Replaced the GPR and starts easy.
Old Feb 3, 2005 | 02:28 PM
AJ21's Avatar
AJ21
Excellent! I will replace the relay as it is much cheaper then the Injection pump, which is what someone else is telling me....
Again,
THANKS!
Old Feb 3, 2005 | 06:04 PM
greygoose's Avatar
greygoose
Make sure your batteries are good. These things need 2 strong batteries to start in cold weather.
Old Feb 3, 2005 | 06:12 PM
3BLADZ's Avatar
3BLADZ
mine is at dealer now for the same thing. they called this afternoon and said the glow plug system checks out good. it would fire like it was going to start and then just crank over & over. I tried cycling the glow plugs (according to the dash lite) but that didnt help.
Old Feb 3, 2005 | 06:40 PM
AJ21's Avatar
AJ21
Well, it appears to be the relay after all. Starts right up and run great!
Thanks
Old Feb 6, 2005 | 08:31 PM
zipper00's Avatar
zipper00
After your glow plug light goes out, wait for about 30-40 sec. before starting. The plugs are still heating after light goes out. The colder it is out side the longer you want to wait after the light goes out. Should work for you................
Old Feb 6, 2005 | 09:29 PM
3BLADZ's Avatar
3BLADZ
Replaced back relay, as it only worked intermittently. We'l see how it does when it gets cold again.
Old Feb 7, 2005 | 06:28 AM
Skeetshooter's Avatar
Skeetshooter
AJ21.. Did you purchase the GPR from the dealer or aftermarket parts store?? If you went the aftermarket route, who did your purchase it through and what was the P/N???
Old Feb 7, 2005 | 09:09 AM
AJ21's Avatar
AJ21
I bought from the dealer as I needed to get on the road again. $100, and I could have saved $50 on ebay, but didn't want to wait another week, oh well! She starts right up now,,,not any hesitation!
Thanks all!
AJ
Old Jun 19, 2005 | 09:40 PM
campingmike's Avatar
campingmike
I have a 7.3 l deisel (1999) that starts hard if I leave it set for more than a day without starting it. It sounds like it is coughing and hacking, and getting ready to spew up a furball. Once it is started thogh and runs a few minutes, it starts right up with no problem, only starts rough if is left unstarted for more than a day, no matter what temperature it is outside, cold or hot. Any idead would be helpful. I have heard that it might be my glow plug relay, where is this located and where can I get one ??
Mike
Old Jun 19, 2005 | 09:53 PM
Kwikkordead's Avatar
Kwikkordead
Mike
Does it belch a lot of smoke before it coughs up it's furball?
Old Jun 20, 2005 | 03:18 AM
campingmike
No. not really, but if I push down on the accelerator as it is doing its coughing and hacking, it seems to smooth it out faster.
Mike
aj88V
Feb 16, 2015 09:03 AM
67aj
Escape & Escape Hybrid
Aug 29, 2014 02:23 PM
67aj
May 1, 2014 08:33 AM
aj3501
Jun 19, 2012 11:29 PM
67aj
Exhaust Systems
Jul 8, 2005 06:42 AM
