Proud owner of 1985 F150 4X4 6 cylincer with manual transmission has a problem with gasoline getting into the crankcase. Fuel pump has been replaced (possible diaphragm trouble). Carburetor has been rebuilt (possible float trouble) but runs a little rich. Any ideas as to what to try next?
If it is real rich then the wetting in the cylinders could be draining past the rings. More likely that the new pump is bad, new doesn't always mean good!
I was wondering if top end has been rebuilt. My last ford f-150 had top end done before I got it. About a month after I owned it the oil smelt like fuel I was thinking the head gasket was going because I was getting alot of fuel and a little coolant in the oil turned out the intake wasnt tight in the rear of the motor.
Thanks for the ideas, guys. I had the Ford garage change out the fuel pump when the problem started (had a 1984 6 cyclinder that failed for this reason). They would not rebuild my carb so I did it myself. It may still be running a little rich since I get an occassional backfire when shutting off. There is a whistle at startup that I believe to be an exhaust/intake thing. It stops as engine warms. Ford wanted $500+ to do the intake/exhaust thing. I said I could live with the whistle - and glad I have since other threads at this site tell that the problem returns after repair. No coolant loss or coloration in the oil - only thin and smells of gasoline. Last sample showed 37% fuel over oil.
