Towing .. Interesting Finding
Old Feb 2, 2005 | 09:51 PM
Aubrey3's Avatar
Aubrey3
Have an 04 SCREW and love it. No problems.
The other day I was towing a light garden trailer ... 12 x 6 angle iron frame, single axel. Total weight ~1000 lbs max. From a power / performance perspective the truck didn't even notice it was there.
However, I was surprised how every bump and wiggle that trailer went over translated into the cab. I had never felt anything like it. My assumption was that the virtues of the ultra stiff frame had consequences in that none of the trailer shock and jolt was asorbed.
Question for the crowd: How do the heavy trailers tow? I am thinking they are better because the trailer weight forces more action in the trailers suspension. No real clue however.
Any thoughts? Experence?
Old Feb 2, 2005 | 11:51 PM
greenroses's Avatar
greenroses
Aubrey3,
I also pull a landscape trailer about the same size as yours. I feel the trailer hitting bumps, but I see it as a good thing, because sometimes I forget it's there.
Old Feb 3, 2005 | 01:05 AM
exiled's Avatar
exiled
Aubrey3
today i hauled my tractor w/ my wfes 04 fx4 scab my 20' trail weighs 1200lbs and my ride was smooth but the trailer has brakes.but the ride was nice.
Old Feb 3, 2005 | 01:13 AM
Bugburp's Avatar
Bugburp
I tow a 5000 lb travel trailer. Don't feel a bump.
Old Feb 3, 2005 | 07:13 AM
samia's Avatar
samia
I have a 4x4 scab and towing a boat I don't feel a thing. Check if you have enough tongue weight on trailer. I had an older boat that had to light of a tongue weight and it road terrible. I think you need some weight up front to get some trailers to pull better. I think when the trailer jumps around it pulls up on the hitch and gives it a weird feeling.
steve
Old Feb 3, 2005 | 08:53 AM
trackdog's Avatar
trackdog
My Problem is Slighlty Different.
While towing a 10x6 trailer with a Polaris Ranger utility vehicle, my whole truck vibrates between approx. 52-56 mph. I should say that when NOT pulling a trailer, I do have a very slight nibble in the steering wheel at EXACTLY 70 mph. I do not feel the nibble below 70 mph, nor do I feel it above 70 mph. HOWEVER, when pulling this trailer with the Polaris, there is much more than a nibble at 52-56 mph range. It does this whether the road is bumpy or not. In fact, it sort of feels like the tires out of balance or something. I wonder if the trailer could be misaligned.
Any one have any ideas.
BTW, I have a 2004 Lariat 4x4, SuperCrew w/ Towing Package, etc.
Old Feb 3, 2005 | 09:30 AM
northbound350's Avatar
northbound350
We pull an 18' alum. boat (approx. 4000#), no problem at all. Pulls like a dream. Check the trailer out behind someone else's truck. Some of those smaller trailers pull great and sometimes you get one that tries to pull you. We also have an 18' car hauler that pulls great behind anything. From experience I'd have to say we are lucky to have trailers that track straight and handle well. Good luck.
Truck: 04 SC Lariat 4x4 w/towing pkg.
Old Feb 3, 2005 | 09:15 PM
truebluefx's Avatar
truebluefx
I have a 6000lb trailer that hauls striping eq. and it rides a little slow, but still very smooth.your trailer may be to light, bouncing around or something. Or you forgot to tighten the hitch or something.
Old Feb 3, 2005 | 09:21 PM
Aubrey3's Avatar
Aubrey3
lol ... The hitch was well tight. It does have a very light tongue. This came across as a complaint. It wasn't intended to be. I was simply sruprised how much of the trailer shock translated up to the cab. I am sure with a heavier trailer/tongue a lot of that will go away.
Old Feb 3, 2005 | 10:45 PM
mtcfish's Avatar
mtcfish
I towed a 7000 lb 23' boat about 100 miles @ 70 mph with no problems.
Old Feb 4, 2005 | 09:26 AM
Genesdsu's Avatar
Genesdsu
Smile No problems towing 9000lbs
I tow a 23 foot Toybox trailer with 3 quads in it and 100 gal of water and fire wood all the time, I estimate the total weight over 9000 pounds.
Used to have jerks and bumps in my 2004 Screw, but I spend a few hundred bucks on some stabalizing jbars and weight distribution bars, now drives like a caddy and I dont even feel the trailer.
Old Feb 4, 2005 | 01:20 PM
TRITON-ic's Avatar
TRITON-ic
I noticed the same. My camper trailer pulled smooth behind my Explorer. I tow it with the 150 now. I appreciate the power, but did also notice the side to side swagger, and jerkiness.
Old Feb 5, 2005 | 10:21 AM
KACalpito's Avatar
KACalpito
i towed a 12 ft boat for about 600 miles thru rain and a little bit of snow and the only problem i had was poor gas mileage @ 10 mpg.
'05 F-150 King Ranch SCrew 4x4
Old Feb 5, 2005 | 07:21 PM
truebluefx's Avatar
truebluefx
the only reason i said to make sure you tighten your hitch is because I forgot to tighten it once and I think i noticed some jerking when I started and stopped. So I was lucky it didn't disconnect and put a huge dent in my tailgate or something. Also you might wan to check the axle in your trailer. Also I forgot to mention that my trailer has 4 tires, so I have 2 axles to smooth out my ride, so it may just be that your trailer is a single axle.
Old Feb 7, 2005 | 09:13 AM
KevinM's Avatar
KevinM
I tow over 7,000lbs, boat and trailer. The tow is much smoother than when I towed with my Expedition with self adjusting ride height.
