Sponsored by: Real Truck
91 350
Old Feb 1, 2005 | 10:23 PM
racerman89013's Avatar
racerman89013
what tells the pcm to ground the injector on a 91 E-350 bus with externaly mounted tfi and I believe hall efects distributor . It is a 460 it has great fuel pump pressure and spark but the injectors are not firing ... there is a constant voltage there witch never fluctuates .......if I crank engine at full throttle it will start but just for a second even if I continue to crank it dies but then will try too restart just for a second again and so on ...does this sound like a bad computer or perhaps a grounded out wire from the injectors how can I test this??????
