oil pressure-based electrical connection?
Old May 1, 2002 | 11:14 AM
Varnish's Avatar
Varnish
Off the back of my '86 f250's 460 there is a distribution block for oil pressure. Out the back of the metal "T" there is what looks like a normal oil pressure sending unit but off the right side there is another connection of some kind holding a two-wire harness connection. The wires coming out of this unit run along the drivers side valve cover and are then bundled along with the distributor & temp sending unit wires. Does anybody know what this additional sensor is called and its purpose?
Old May 1, 2002 | 01:59 PM
Franklin2's Avatar
Franklin2
If the wires going to it are red/yellow, then it's a switch inline to the fuel pump relay. It cuts the fuel pump off in case the engine quits, along with the inertia switch in case you are in an accident.
Old May 1, 2002 | 04:24 PM
Varnish's Avatar
Varnish
thanks, thats it
Old May 1, 2002 | 04:29 PM
canadianfordman's Avatar
canadianfordman
