Hydraulic roller cams
Old Feb 2, 2005 | 06:40 PM
Sand Bronco's Avatar
Sand Bronco
Is there any company that makes after market Hydraulic roller cams for big blocks?
Old Feb 2, 2005 | 07:49 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Crane make a good one for FE motor's...the 349521..and the 349541...
Both a very streetable!!
Russ
Old Feb 3, 2005 | 01:32 AM
Homespun91's Avatar
Homespun91
Crane & Lunati both make hyd. rollers for the 429/460 engines.
Depending on what you want the cam to do, you may want to consider a solid roller instead. The pushrod angle in these engines is not the best and is aggravated by the raised height of a hydraulic roller lifter. For mild builds it's likely not a problem; for relatively serious engines, a solid will be more reliable. The hyd. choices are also fairly limited.
Also depends, I suppose, on whether you are OK with occasionally lashing the valves, or never wish to see them again after the engine is closed up.
