Auburn mini spool
Old Feb 2, 2005 | 05:26 PM
okiebronc's Avatar
okiebronc
Auburn mini spool
Can anyone tell me about this locker, Auburn Mini Spool??
EBay- 7950523080
Okiebronc
Old Feb 2, 2005 | 08:06 PM
SoCalDesertRider's Avatar
SoCalDesertRider
I didn't go to the ebay listing to check it out, but a 'mini-spool' goes in the stock open diff case and replaces the spider gears. It eliminates all differential action and solidly locks both axleshafts togther, as if they were one continuous axleshaft from one wheel to the other.
A spool isn't something you will want to put in a truck you drive on the street alot, but if you're mud bogging or drag racing, it will work great.
Before you bid on it, make sure it has the same number of splines as your axleshafts, since some axles come with different axle spline counts depending on application.
Four.on.the.floor
May 15, 2015 02:19 PM
BrianA
Alabama Chapter
15
May 11, 2009 11:08 PM
scottie2hottie
Nov 4, 2004 09:47 PM
The Tree
1978 - 1996 Big Bronco
Feb 24, 2004 11:58 AM
