Walker downpipe
Old Feb 2, 2005 | 04:29 PM
1982fordf100's Avatar
1982fordf100
Walker downpipe
Now that I have my EFI manifolds for my 82 F100, im looking for the correct walker downpipe. I searched the forum and found part number 45166. Walkers website lists 15739 for 87-95 years but that looks like it comes with a cat which I don't need. I just want the downpipe. For those of you that have the walker downpipe is 45166 the correct number? Also what is the diameter of the downpipe, I think its 2 1/2 which should work great for my 300. Thanks Fred
Old Feb 2, 2005 | 05:11 PM
5_labsownus's Avatar
5_labsownus
45166 is the right number for "F" series. The pipe dia is 1.5 inch and it will fit around the starter and over the cross member.
Old Feb 2, 2005 | 06:04 PM
1982fordf100
Thanks for the info. I found advance auto parts has the downpipe for $55.88. I heard JC whitney has them but I had no luck finding them on the website or in the catalog. I'll check napa as well, but the website for them is down right now. Where did you get yours and how much did it cost? Thanks Fred
Old Feb 3, 2005 | 05:54 PM
5_labsownus
NAPA listed them for about $60.00 but a chain store "Bumper 2 Bumper" ordered it for me at $69.00 and would let me take it home to see if it would fit and if not return for a refund!
Old Mar 12, 2005 | 08:34 AM
MP1's Avatar
MP1
Can I ask a silly question?
My mechanical knowledge pretty much stops at basic stuff like brakes/plugs/filters/alternators, etc.
I'm spending tons of time in here trying to learn as much as possible and eventually start upgrading my 1994 EFI I6 4.9. Would somebody mind clueing me in on this 'downpipe'.
What part, exactly, is this and what/how big an effect does it have on the performance?
Thanks!
MP
Old Mar 12, 2005 | 12:14 PM
asa67_stang's Avatar
asa67_stang
it is for use with the EFI manifolds
basically it's a y-pipe
since you've got a '94, you can either opt to use this, or take your stock piping up to the first cat and run dual exhaust with that (what i did)
you'll have true duals with this method
Old Mar 13, 2005 | 07:17 PM
Franken-Truck's Avatar
Franken-Truck
It is 2 1/2" diameter. When you get it, look down the second, short pipe and see if it needs to be "deburred". I had to grind out 1/2" of material from inside this pipe.
hillcountryflt
May 11, 2014 08:52 PM
johnboy427
21
Nov 14, 2011 12:34 AM
blueovaldave
Aug 21, 2009 12:43 PM
drive_old_ride_new
Jun 6, 2006 03:36 AM
1982fordf100
Mar 1, 2005 12:44 PM
