suspension options?
Old Feb 2, 2005 | 01:34 PM
wlihntr's Avatar
wlihntr
Question suspension options?
is there any way to get; heavy service front springs,steering damper,rear anit sway bar, and rear overload springs on a '05 xlt sport 6.0 auto? it seems you can get all but the steering damper or all but the rear anti sway bar.
Old Feb 2, 2005 | 06:50 PM
polarbear's Avatar
polarbear
Correct- and there's a darned good reason for that too. The HD service pkg increases the front height of the truck, and is specifically designed for winch or other aftermarket applications mounted on the front of the truck. Ford disclaimer: *Recomended only on vehicles which will permanently utilize aftermarket equipment which will load the front axle to the designated GAWR. May result in deterioration of ride quality. Vehicle ride height will increase with the addition of this package. Putting a Rr Stabilizer on that suspension changes the design parameters of that option (eg: weight in the front, not the bed of the truck).
Old Feb 2, 2005 | 11:21 PM
wlihntr's Avatar
wlihntr
well that doesnt make any sence, i can get the camper package whitch has heavy service front springs and the rear anitsway bar as well as the over load springs but no steering damper. what negitive effect could the streering damper have??????
Old Feb 3, 2005 | 12:18 AM
polarbear's Avatar
polarbear
It doesn't revolve around the steering damper, it revolves around the HD Service Pkg. The Camper Pkg includes the front spring off of the HD Serv Pkg, but that's the only component it includes. The HD Serv Pkg is a different front suspension. Unfortunately, the steering damper isn't a menu option, but the real issue is whether the HD Serv Pkg is a good idea for a customer thinking in terms of Camper/Towing. Fords disclaimer is quite clear here : *Recomended only on vehicles which will permanently utilize aftermarket equipment which will load the front axle to the designated GAWR. May result in deterioration of ride quality. Vehicle ride height will increase with the addition of this package.
So: If Camper/towing is the primary use, go with the Camper pkg. If you intend to hang something off of the front that will max the GAWR of that front axle (as in, a permanent install), go with the HD Service pkg.
Old Feb 3, 2005 | 08:23 AM
caddofarmer's Avatar
caddofarmer
camper package and fx4 off road package will give you all of those....
Old Feb 3, 2005 | 12:32 PM
polarbear's Avatar
polarbear
Yep- everything except the steering damper.
The Northwest Chapter of FTE
we don't get lost,
we just get found
Old Feb 8, 2005 | 05:56 PM
nhebert's Avatar
nhebert
So how much weight does a winch weigh on the front springs ? Im thinking of getting one, maybe not on a 300 lb bumper but something that would hold the winch ? I know nothing about winches, obviously. At least the ones that are on 4x4 trucks.
