A healthy battery shouldn't run down in two weeks unless there is an abnormal drain on it. Are the terminals clean? You can charge or jump-start the battery while it's in the vehicle. See your owners manual for directions on jump-starting.
I put it on a charger at two amps for about 3 hours and it started right up. The "eye" on it is still showing red so I am still wonderingabout the condition of the battery. I sent the wife out in it on a 20 mile highway run. Will see if it starts in the morning.
Terminals are tight and spotless. I only have about 8K on it. Everything looks like the day it came from the dealer.
Sounds pretty normal to me, usually only takes a obut a week to 10 days. It may be to dead to jump, in which case a trickle charge would be in order. Check the water levels and make sure the connections are tight and free of corrosion while you're at it. Even if it will jump, the alternator really can't add any juice to it, so it still may require some charging to keep it up. I've had batteries last through numerous charges, and for years after being charged more than once, and letting it get bone dry.
