How much will the front end drop by installing a warn HS9500i and a transformer
winch mount? (Grill & Brush Guards) This install on a 2005 F-350 (drw)
King Ranch. I have the 13000lb GVRW truck.
Thanks.....
I do not think it will drop the front end muc at all. If it does, I would be surprised if it is noticeable. That winch wieghs 120# tops. Floorshow's suggestion is a good one. You might have your girlfiend or wife stand on it though if you want and accurate check.
To check out markethopper's gallery, point the mouse over his name (upper left hand of post) then left click. A menu will drop down. Select, "View Gallery" .
Curious if you intend to do a hidden mount or whether you intend to mount on a bracket that inserts into a front receiver?
Texan2004, I just ordered the Transformer winch grill and brush guards in stainless steel
for my 2005 King Ranch F-350 CC, (DRW) I had to wait 4 months for them to make it. The truck was to new for Warn and they had to fab some up when I ordered it, Should be in this week....
