gears.
Old Feb 2, 2005 | 01:18 AM
south bay 6.0's Avatar
south bay 6.0
gears.
i own a 04 6.0 4wd with a 12" lift on 40" tires. any suggestions on what gears i should replace the stock 373's with. i've heard 456 or 513's. thanks.
Old Feb 2, 2005 | 08:22 AM
bogginf350's Avatar
bogginf350
I had 4.56 and 38 inch ssrs on my 6.0. The gearing was a little lower than it ran stock, higher highway rpms. I think with 40`s it would be just about perfect. You will def. notice a big increse in power and it makes it alot easier on that torqueshift..
Old Feb 2, 2005 | 09:09 AM
bighoss550's Avatar
bighoss550
i have 4.56's in my bronco with 40" swampers. its the perfect match. speedo is pretty close. the bronco and ur SD had about the same tire size and gears factory, so id imagine thats ur best bet
Old Feb 2, 2005 | 10:09 AM
Daryl Hunter's Avatar
Daryl Hunter
Depends, do you want to get back to the equivalent stock ratio with the 3.73 and the 265/75R16s or do you want something lower?
The stock tires have a calculated diameter of 31.65 inches so if you divide 40 in by 31.65 and multiply the result by 3.73 you come up with 4.714.
So you could go with the 4.56 or a 4.88 if you want something a tad lower geared.
suke
Dec 23, 2012 09:27 PM
lg405
6.7L Power Stroke Diesel
Aug 19, 2012 07:01 AM
domain311
May 14, 2006 07:52 PM
jkravito
Dec 4, 2005 05:13 PM
m350
Oct 6, 2003 08:42 PM
