Engine Rebuild Options (94 Explorer)
Old Feb 1, 2005 | 09:43 PM
Gil Chesterton's Avatar
Gil Chesterton
Hello,
Some of you may recognize me from my previous adventure (see thread "94 Explorer Won't Start").
I have the heads off the motor (motor in place). Number 6 piston has a 3/4 inch long crescent moon shaped piece missing out of one side (not good). Number 6 had zero compression before I removed the head (the other 5 were OK). Heads, valves, rods lifters look OK for major structure. No major (obvious) damage to the cylinder.
The short block is still in the chasis. I have to remove the block from the 94 even if I swap (I have a 1991 4.0L motor in the Explorer I drive). I'm in no rush to get the 94 on the road (project truck). I plan to work ALL of the 94 (front end, exhaust, body, paint etc) so I want a motor to go 5 years minimum.
Which way to procede? Pull the 94 and rebuild? Slip the 91 into the 94 (91 has 210K miles, 94 had 170K miles but was "rebuilt" 12 months ago according to previous owner). Buy a crated short block or long block. Find a good used 4.0 with lower milage?
I have never done anything beyond the heads before but I don't mind learning as long as the expense makes sense (crank, bearings, cylinders, heads done etc).
Any suggestions??
Gil
Old Feb 2, 2005 | 11:29 AM
zebadoba2's Avatar
zebadoba2
Go pop into the "2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6" forum. I was in there a while ago and they have tons of post on "how to" and where to buy a crate engine.
Andy-
Old Feb 2, 2005 | 11:43 AM
Gil Chesterton
Thanks for the advice.
When I posted I considered the "engine size" forum you mentioned AND "Engine Swap" forum AND the one I posted in (small chassis trucks). It's hard to figure which forum is the best!
I'll go look at the 4.0L forum.
Thanks.
Old Feb 2, 2005 | 01:42 PM
zebadoba2's Avatar
zebadoba2
Cool, then you are on top of it. Do let us know what you decide. While I am not quite ready to do a swap, I am currious as to what is invloved. I was looking at west LA engine they have a web address, but the stupid forum will not let me post a link.
Andy-
