not running when hot
Old May 3, 2002 | 10:46 PM
4Zsnow's Avatar
4Zsnow
Old May 9, 2002 | 08:01 AM
UPVFD30's Avatar
UPVFD30
[updated:LAST EDITED ON 09-May-02 AT 09:23 AM (EST)]I have a 1980 ford f-150 with a 302. When it gets warm it will shut off and will not start back till it cools off. what could this be. I have put a new coil pack, spark plug. What else could be wrong. I am out of ideas. thank you for your time.
Old May 9, 2002 | 11:50 AM
dvlinnell's Avatar
dvlinnell
Sounds like your module.
Old May 9, 2002 | 07:29 PM
Wilber15's Avatar
Wilber15
If it ain't broke.....change stuff till it is!
The Ignition Module on the front of the distributor might be bad...try replacing that.....
Old May 9, 2002 | 08:48 PM
Franklin2's Avatar
Franklin2
If he has an original 1980 set-up, the module will be mounted on the drivers side fenderwell.
Old May 10, 2002 | 12:16 PM
UPVFD30's Avatar
UPVFD30
thanks guys. I changed that about 1 year ago. But it could still be bad. thanks
