computer check
Old Feb 1, 2005 | 07:42 PM
doug96's Avatar
doug96
computer check
sorry if im in the wrong fourm
i would like to buy my first ford in a couple days
96f-350 4x4
how can i check to see if the computer is ok ? i saw that the air conditioning compresser was not on, just laying off to side, will this affect it
Old Feb 2, 2005 | 06:30 AM
trike1946's Avatar
trike1946
I do not believe the computer has anything to do with the ac. Does the truck start? What engine, how many miles? Is the check engine light on? If the compressor is laying off to one side, they probably are having some kind of problem. Ac fix can be easy and cheap or real expensive.
Old Feb 3, 2005 | 06:29 PM
doug96's Avatar
doug96
its a 96 f350 with 351 95000 may have flipped, no hundred thou dial, on used car lot with bad reputation hes asking $6900 has a 8 ft fisher commercial plow so i suspect is been beat on
n.y inspection has become impassable unless all sensors and cpu working good, it ran ok
no engine light smelled like oil burning though.
i really like the truck but he also not giving 30 day warrenty that most used dealers do
i am very suspious of it breaking down majorly like engine or 4 wheel drive components
Old Feb 3, 2005 | 06:49 PM
trike1946's Avatar
trike1946
If the dealer has a bad reputation, you should check the codes yourself. What if he pulled the bulb or something so it wouldn't light. Did you check the fluids? Do any of them smell bad? Any puddles under the truck? If the trans is an auto with that many miles and a plow, it is ready for a trans. I would be suspect of not getting any warranty. Maybe you could take it to a mechanic and have it checked over. Do a compression check. You can also check it with car fax. Most dealers give you the report around here. Good luck with it.
Old Feb 3, 2005 | 09:33 PM
Franklin2's Avatar
Franklin2
All the lights should come on when you first turn the key for a bulb check.
Old Feb 3, 2005 | 09:43 PM
AlfredB1979's Avatar
AlfredB1979
Bad stealership + truck that needs work = find new lust for a truck!
Good lust, errr, luck.
