1 ton conversion info a plenty
Old Feb 1, 2005 | 07:20 PM
1ton460bronco's Avatar
1ton460bronco
hi i'm matt and i've done many coil to leaf swaps, ttb to solid swaps and big block swaps. I also have a background in mechanical engineering and fabrication so hopefully i can assist in any conversions needing advice. I also have many questions for other truck guys. see ya in the treads.....
Old Feb 1, 2005 | 07:52 PM
Fordlover55's Avatar
Fordlover55
Still kicking!!
Welcome aboard! There's several forums you should be quite helpful in..thanks!
Please take a few minutes and read the Forum Guidelines and the READ FIRST notes in each forum you check out. They'll help use the site as effectively as possible. Thank's for joining us!
Old Feb 2, 2005 | 07:40 AM
Icicle's Avatar
Icicle
Where are you from? dont forget to check out your local chapter that corresponds to where you live...welcome to the group
Sickminds
New Member Introductions
Feb 2, 2005 11:39 PM
hotrod66_57
Feb 1, 2005 08:26 PM
49panel
Jan 29, 2005 08:52 PM
gdawghereiam
Jan 16, 2005 11:43 AM
Sam Smanko
Oct 6, 2004 09:38 AM
