Pics of my E150 being "gutted"
#32
#33
Crab452,
If you wanted to remove the shifter and have a finished appearance afterword, you might be able to use a plain column collar from a F series truck that has a floor shifted manual transmission. A column collar from that application would give you a finished appearance.
Does your touch pad have any additional capacity to control anything else? If so, you might be able to control the OD function from it.
Gene
Gene
#34
Originally Posted by Gene W
Crab452,
Gene
Gene
Will the F-series collar fit up with the dash properly?
#35
I use hand controls on the left of the steering column, do you use the same?
Hand controls have a pivot mount on the steering column mounts under the dash, a bar with a hand grip is on the pivot, rods run to the actual pedals, so the rod movement controls the pedals, but the pedals are still functional.
I'd love a floor drop, I don't need it as far as yours since I transfer into my drivers seat on the 6 way power base, I'd like the regular drop mid van so I don't keep hitting my head.
#36
#37
The gas and brake pedals are physically pushed/pulled by a four pole motor mounted next to them. When it spins one way, it hits the brake. The other, it hits the throttle.
Its pretty amazing.
#38
Some more photos, in case anyone is still following.
Went for my last fitting today. Positioned the ez-lock, and the gas/brake pole and box.
I will have it May 9.
Two problems that will be fixed:
1 - My HVAC does not work properly. It will not switch modes, it seems to be blowing out the front floor vents only.
2 - The washers do not work when the blinker stalk is pushed, but should. Works okay on the touchpad.
She'll need an aggressive wash and detail, it'll look good.
PHOTOS
PHOTOS
#39
#41
It came out very well...I've had a few problems, though.
The touchpad went bad the first week I had it, leaving me stranded. My ignition, gear selector, etc is in that pad only. Took a week to get fixed.
The HVAC control module failed. No A/C for a week..in this recent N/E heat.
I really do owe you guys that have been following this some pics, and all I have right now are kind of a let down...I've posted what I have in my gallery...last two pics.
Tomorrow I will try for some detailed pics and some videos.
-Cory
-Cory
#43
Man, I feel really dumb right now, but I can't seem to find the pics. Maybe I'm too new to this website to understand where I go to see them. Furthermore, I wasn't able to access any of the other links listed that had the pics posted (my browser said that umbrella.xomar couldn't be found).
This thread is intriguing and I really want to see the pics. Can someone please point me to the pics? I tried clicking your name (crab) and viewing your galleries, and I also tried going to the galleries page with no luck with either.
I am an idiot.
I am an idiot.
