engine swap
Old May 12, 2002 | 12:27 PM
kford1's Avatar
kford1
engine swap
how hard is it to put a 390 motor into a 86 f-150 that had a 300 in it
Old May 12, 2002 | 02:20 PM
rc351w's Avatar
rc351w
engine swap
The easiest way is to find a '76 or older F150 that has a 369/390 in it. Your goning to need the motor mount perches, tranny, drive shaft and maybe the rear end for starters.
Have fun, good project if you got the time.
Old May 12, 2002 | 06:46 PM
Jimbare's Avatar
Jimbare
all alone in the world
engine swap
only hard part will be finding a rear sump pan for an f e block. perches are the same six to f e block. what tranny do you have?
Old May 12, 2002 | 08:54 PM
kford1's Avatar
kford1
engine swap
i have the tranny that came with the motor
Old May 12, 2002 | 09:14 PM
Franklin2's Avatar
Franklin2
engine swap
80-up never came with an FE engine, so I bet there will be lots of issues and engineering involved.
Old May 13, 2002 | 02:03 PM
UPVFD30's Avatar
UPVFD30
engine swap
