1978 - 1996 Big Bronco
Wiring A 351 M
Old Jan 31, 2005 | 08:02 PM
ryanjap33's Avatar
ryanjap33
Wiring A 351 M
Hey Guys,
I am currently restoring my 78 Ford Bronco with the 351M. I did some engine work and right now all that is in my garage is my chassis. Before I put the cab back on and begin the paint process I wanted to make sure my engine ran because it is so much easier to work on with no cab. Is there a way to fire the engine up without the wiring from the cab? and if there is how can I wire it to get he engine to fire over without all the wiring from the cab.
Thanks Guys, and any advice is welcome
Old Feb 1, 2005 | 08:59 AM
Kemicalburns's Avatar
Kemicalburns
im not sure, but was curious if you thought about also needing the radiator hooked up otherwise you cant run that motor
Old Feb 1, 2005 | 03:56 PM
ryanjap33's Avatar
ryanjap33
Yeah, I can hook that up because I will still put the radiator support back in, just not the cab compartment.
