Sponsored by: Auxito
Payload package
Old Jan 31, 2005 | 12:05 PM
DannoNY's Avatar
DannoNY
Payload package
I'm considering buying a 2001 f-150 2wd longbed for work, can I tell from the door tag if it has the upgraded rear payload? It says 5600LB GVWR, 2900LB Rear GAWR. Is this the lesser of the suspensions? Thanks.
Old Jan 31, 2005 | 03:45 PM
Robbywayne's Avatar
Robbywayne
Trailering
Payload
5600 lbs is the minimum weight package for that truck.
Old Jan 31, 2005 | 04:20 PM
ddrumman2004's Avatar
ddrumman2004
GVWR.....Gross Vehicle Weight Rating.....so that would be maximum weight of the truck with evrything in or on it.
GAWR....Gross Axle Weight Rating...
Old Jan 31, 2005 | 04:34 PM
DannoNY's Avatar
DannoNY
Thanks for the info, my 2000 F-150 had the 7700LB GVWR with the Triton 5.4. I'll probably look for that combo again.
