Power Steering Problems
Old May 22, 2002 | 03:44 PM
Syzle's Avatar
Syzle
I have some insanely hideous noises coming from my Power Steering. I need to drain the fluid and put more fluid in, whats the easiest way to drain it?n The fluid hasn't been changed in a long time, and it looks pretty bad..
Old May 23, 2002 | 06:24 AM
madman211's Avatar
madman211
On my 80 F150 there is a hose at the bottom of the powersteering pump Use a screwdriver to unscrew the clamp then pull it off and all your fluid will drain out.
steve
Old May 23, 2002 | 01:16 PM
Franklin2's Avatar
Franklin2
