EGR Question
Old Jan 31, 2005 | 08:08 AM
oldspiker's Avatar
oldspiker
EGR Question
If I want to replace the EGR valve in my 1983 300 I-6, what does it entale? Do I just unbolt the two bolts and slide it out, or are there internal parts that are connected to the valve itself? What does it take before I get myself in a fix.
Thanks, Arnie
Old Feb 1, 2005 | 12:16 AM
tetraruby300's Avatar
tetraruby300
Two nuts, that's it. You may want to put a little penetrating fluid on the nuts and hit the threads with a wire brush to clean them up. I'm sure they have corroded a little over the years.
Old Feb 1, 2005 | 09:59 AM
oldhalftons's Avatar
oldhalftons
take of the 2 nuts and make sure you use a new gasket.
Old Feb 2, 2005 | 07:21 AM
oldspiker's Avatar
oldspiker
Thanks for the answer. Bye the way, does the gasket go on dry, or with some silicone gasket sealer?
Thanks, Again.
