Bouncing '00 Ranger
Old Jan 30, 2005 | 09:16 PM
FtblShwn10's Avatar
FtblShwn10
Exclamation Bouncing '00 Ranger
I have a 2000 XLT Ranger 3.0L 4x4 with about 68k on it. I got the truck used in August of '03 and didn't notice any problems until about 3 months ago. When I first start accelerating, the truck kind of jolts like it is downshifting or something but its not a hard jolt its more of a shudder. A friend said he thought it might the the U joint, but I wanted a second opinion.
Another thing I've noticed is when the heat or AC is on there is a click in the engine like something is kicking on, and when I'm in motion I can feel a loss of power for a brief second. No clue what this is.
Finally, with gas prices so high I've been using the low grade gas and the engine dings and pings pretty badly at times. If i use the Mid grade gas its not so bad but I read somewhere that the Rangers are supposed to take the low grade. How can I stop this as well?
PS> Are the instructions for removing the bezel the same for the 98&up trucks as the pre-98 trucks?
Old Jan 30, 2005 | 10:53 PM
98xlt4x4's Avatar
98xlt4x4
Your jolting deal is most likely the driveshaft slipyoke. Look at some of the 'sticky' posts at the top of the forum and you'll find more info about it. The problem is easily fixed by simply greasing the slipyoke.
The click and loss of power with the heat and a/c is just the compressor (for the A/C) engaging and disengaging. Perfectly normal. If you set the ***** so that the air only comes out on the floor, or only the front vents, the compressor won't engage. Should save a slight bit of gas too.
As for the engine pinging, it's also common with the 3.0L. Mid-grade will probably fix it, but it's more of a sidestep to fixing it. Again, read some of the sticky posts at the top of the forum, as this has been covered many times also
Any finally, the bezel (stereo I assume) has been the same from 95-current.
Good luck and WELCOME TO FTE!!! This site is full of great info and knowledgeable people, take advantage of it
Old Jan 31, 2005 | 08:55 PM
FtblShwn10's Avatar
FtblShwn10
Thanks for the help!
BTW, where are the 'sticky posts'?
Old Feb 1, 2005 | 07:24 PM
Ken00's Avatar
Ken00
There at the top of this forum, https://www.ford-trucks.com/forums/s...d.php?t=107538
