transmission fluid
Old Jan 30, 2005 | 08:43 PM
cd014706's Avatar
cd014706
transmission fluid
I just changed my transmission fluid and filter. I replaced the fluid with dextron IIII / mercon is this ok or should i drain it an add something else. Im not sure so im asking .
Old Jan 30, 2005 | 10:18 PM
zog02's Avatar
zog02
Straight mercon is what you should add. From what you have written you have the correct fluid in there. As long as you don't put Mercron V you are fine. Its hard to find straight Mercron but Dextron III / Mercron is ok.
Old Jan 31, 2005 | 06:55 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
cd14706..
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
Old Jan 31, 2005 | 11:20 AM
02PSD4ME's Avatar
02PSD4ME
dextron IIII / mercon are the same.
Just DO NOT use Mercron V
Old Jan 31, 2005 | 05:44 PM
Oneof6's Avatar
Oneof6
Additionally, Mercon V / Mercon dual use fluid is not recommended in the 4R100 transmission. I use Mobil 1 synthetic (Mercon rated), cost 5 bucks per quart. Total flush will set you back about 100 bucks for a DYS job. Probably don't need to change the filter but every other flush.Takes about an hour to do the full system flush yourself. All you need is a 5 gallon bucket, 10' of 3/8" clear hose, 20 qts of ATF and a few wrenches. WallMart will take the waste oil. Good luck.
