aod tv cable adjustment
Old Jan 30, 2005 | 08:40 PM
pageparsley's Avatar
pageparsley
my aod has some slipping in fourth gear. the tranny has just been rebuilt and ive only driven it less than 10 miles. is there any way i burnt it up driving that far with a properly adjusted tv cable? or do i need to adjust it some more to clear up the problem. could someone please tell me the easiest way to prop[erly adjust it.thanks
Old Jan 31, 2005 | 04:19 PM
rclarke's Avatar
rclarke
The direct clutch in an AOD can be fried in 2-3 miles with the tp cable disconnected or badly adjusted. The proper adjustment requires an oil pressure gauge hooked to the tp oil circuit and a tool to pull the cable to the adjustment position so that the housing can be adjusted for proper oil pressure.
