1978 - 1996 Big Bronco
Help!!
Old Jan 30, 2005 | 08:14 PM
racin883r's Avatar
racin883r
Help!!
I am rebuilding the motor in my 89, a 351w, 3sp, auto, i need ideas on performance/motor set ups. Please help...this is my first ford rebuild
Old Jan 30, 2005 | 08:24 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
Old Jan 30, 2005 | 09:37 PM
mjl351w's Avatar
mjl351w
Well 1st are ya gonna keep the EFI ( if you have emissions testing you might have to) 2nd how much $ can you spend becuse to improve the "speed density" EFI system you have now there is not too much you can due with it, you can convert to "MAF" mass air flow for around 600$ and due what ever you want , cam, heads, timing curve......i converted mine form EFI to a carb very simple and i did it all for around 900$ carb to pan . it will turn over 6,000 and as beat as it looks will smoke must newer V-8 trucks on the road
Old Jan 30, 2005 | 09:44 PM
racin883r's Avatar
racin883r
I have emissions testing so i wanna try to keep EFI, Budget is about 3K.
Old Jan 31, 2005 | 02:16 AM
greystreak92's Avatar
greystreak92
Not entirely true. There are many bolt-on aftermarket performance products that will work just fine with your speed density EFI. Cams and heads are a little tougher but as long as the cam lobe separation is kept within certain tolerances it can be done. Check with you performance parts distributor. Yes conversion to MAF (mass air Fuel injection) virtually eliminates these concerns but it doesn't mean you are stuck with whatever perfomance your stock speed density truck has. Cold air intakes, Edebrock's Performer series intakes for the EFI Ford 302 and 351 truck engines, BBK's larger bore throttle bodies, not to mention the ignition systems and exhaust and fuel injectors are just some of the options you have. High performance has more to do with getting air/fuel IN and OUT more efficiently than anything so anything that will improve these areas will help.
JOD F100
New Member Introductions
May 24, 2016 02:27 PM
Thedonk
Dec 28, 2015 03:43 PM
robjs111
Sep 26, 2012 01:36 PM
76f250highboys
May 17, 2010 11:42 PM
tanman722001
North Carolina Chapter
13
Nov 6, 2006 09:28 PM
