Transmission kickdown
Old Jan 30, 2005 | 06:23 PM
72earl302's Avatar
72earl302
Lightbulb Transmission kickdown
I have a 1972 f-100 with a 302 in it. I have installed an edelbrock performer 289 intake and 650cfm carb on it, and like them both. But you can't use the stock transmission kickdown rod on this setup, and I am really missing the transmission being in the right gear when I stomp it. Is there a bracket that I can use the stock rod with, or can I rig an electronic kickdown?
Old Jan 30, 2005 | 06:44 PM
TheWiz427's Avatar
TheWiz427
Mine is a 600 holley and it has the lever for the kickdown on it.I made the mistake once of just buying a carb without making sure of the application and found out about the kickdown afterwards. You need the carb with the kickdown lever for a Ford and everything will hook up right.
Old Jan 30, 2005 | 07:43 PM
72earl302's Avatar
72earl302
I looked throught the edelbrock catalog and searched jegs but I couldn't find anything to adapt the carburetor to use the kickdown rod
Old Jan 30, 2005 | 08:26 PM
TheWiz427's Avatar
TheWiz427
I don't know of any adapter for the kickdown ,You won't be able to use kickdown if the carb does'nt have the lever for it.
Old Jan 30, 2005 | 10:29 PM
fordxxx's Avatar
fordxxx
Edelbrock has a THROTTLE LEVER ADAPTER part number 1483 but they refer to a kick-down cable not a rod like our trucks have. It says it is for 1968 and later automatics except AOD.
www.edelbrock.com/automotive/index.html
Old Jan 30, 2005 | 11:13 PM
sacf250's Avatar
sacf250
yes there is a a kick down bracket I wish I could remember the number it might be the 1483 like said above. You also need the throttle relocation bracket. I just put a eldelbrock carb on my bronco a month ago and needed both. and any ford auto needs it if you use a edelbrock. Holly dosnt need on because the acount for it. I think is because holly does alot of the ford stock carbs so they are more of a ford carb. where edelbrock is more of a chevy carb. I got mine from schucks and they new what I was talking about as far as the kick down bracket but I had to ask for the throttle relocator.
Old Jan 31, 2005 | 08:16 PM
sacf250's Avatar
sacf250
i have found one of the parts number it is 1491 i belive and the other one I think is the 1483 like abouve
Old Feb 1, 2005 | 10:49 AM
72earl302's Avatar
72earl302
will these plates work if my throttle is not a cable?
Old Feb 1, 2005 | 10:15 PM
sacf250's Avatar
sacf250
not to sure the 1491 is to relocate it over a few inches so you can use the kick down . the kick down bracket ads a few inches to the linkage so the throttel needs to be moves over. It just sucks that holly take this in to account and eldelbrock dosnt but they gett you for another $40.00 bucks for the two brackets. what type pf throttle
Old Feb 2, 2005 | 09:04 PM
72earl302's Avatar
72earl302
the #1483 got the kickdown to work but it interferes with the throttle. So, should I get a new throttle connector (from the pedal to the carb), or should I convert it to cable or get a new cable pedal assembly?
Old Feb 7, 2005 | 10:54 AM
72earl302's Avatar
72earl302
I was trying to fix my throttle when i noticed that the entire pedal mount was broke, so i went to the junkyard and got a pedal and linkage off of a late 70's or early 80's model and it worked perfectly without interference because it was bent a little differently.
Thanks for all the help with the brackets
Old Feb 7, 2005 | 08:39 PM
sacf250's Avatar
sacf250
good to hear that
Old Feb 8, 2005 | 12:46 AM
Janet40's Avatar
Janet40
Thats what i was going to suggest is going to a salvage yard, most of these guys know the tricks for this type of stuff, i know another way it could have been done, you would need fine strong cable a drill and some eye bolt ends and messure, but i could fabricate that at my house i know....Janet
