My 95 150 wont Git Up
Old Jan 30, 2005 | 05:28 PM
kiecker's Avatar
kiecker
I have a 95 150 with a big V8 in it .
Runs great unless I really get on the gas. Then it shakes and chugs . I can be in Park and do this so I dont suspect drivetrain or anything. I bought this truck off a buddy just recently and he had no idea either... Any help or ideas would be appreciated. Thanks alot.. Nobody likes a truck with no nuts!!
Old Jan 30, 2005 | 08:16 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
Old Jan 30, 2005 | 10:10 PM
mako5972's Avatar
mako5972
Did you put a code scanner on it and retrieve the codes? If not, do so.
Old Feb 2, 2005 | 06:31 PM
kiecker's Avatar
kiecker
The check engine light isnt on.. but
Ill try that out .. Thanks for your help.
M
Old Feb 2, 2005 | 06:47 PM
bhartman78's Avatar
bhartman78
I would also look at a misfiring spark plug or crack in the cap/rotor. If is was gas, it would probably not even start. I would check out the electrical system. ie the coil,cap/rotor,spark plugs, and plug wires. I just put a set of plug wires on my 93 and that took the herky-jerky out of excelleration.
Old Feb 3, 2005 | 10:11 AM
Kemicalburns's Avatar
Kemicalburns
cutting out when you hit the gas is one of 2 things. either a fuel issue (clogged fuel filter) or clogged Caty converter. I would start by doing a good tune up your rig. new plugs (autolite copper) ford 9mm wires, cap, rotor. set timing to 10*btdc and replace fuel filter. start there if it continues then i would suspect the cat as colapsed
