Edelbrock intake
Old Apr 21, 2002 | 02:04 PM
hungrymonkey's Avatar
hungrymonkey
Edelbrock intake
Old Jun 4, 2002 | 09:11 PM
Martin85xl's Avatar
Martin85xl
Edelbrock intake
Has any one used the Edelbrock performer intake for the 351w ? I know that leaking is sometimes a problem but I'm beginning to think there may be fit problems too.I'm using the non EGA model # 2181. I've got white exhaust on the right bank and I guess this is water entering the combustion chamber. No visible leaks though. And i'm not going through water like I was after the first install. 3rd times a charm.
I used a fel-pro gasket non valley type, with ultra grey rtv on the ends. Torqued to 25 ft lbs several times through. Can the manifold draw up on the heads, I've heard that heads bolts are sometimes torqued an extra 10 ft lbs to offset this effect. could I have caused a head problem. The problem is more pronounced during acceleration. +
