power steering conversion kit
Old Jan 29, 2005 | 04:30 PM
74hiboy's Avatar
74hiboy
I'm looking for a kit to convert the power steering on my 1974 F250 4X4 to the newer style. I know that there was a conversion kit on e-bay for sale but I cant find it. Does anyone know where I can buy a complete conversion kit? I am aware of the other option of utilizing a doner 78 or 79 setup.
Thanks
Old Jan 29, 2005 | 06:13 PM
ozzy460's Avatar
ozzy460
i have the email address for the guy on ebay that sells the kits. i will be ordering one soon. i will list his address later. also he sells rear tanks conversions for highboys. found it sledding.betty@verizon.net if it doesn't work check item #7940289664 on ebay its an old listing but should be able to ask seller a question good luck
Old Jan 29, 2005 | 06:37 PM
Mil1ion's Avatar
Mil1ion
This thread is being moved to the Specific Steering Related forum.
Old Feb 16, 2005 | 01:11 AM
Cheapevil's Avatar
Cheapevil
I dont understand why you are moving this post, it has to do with 73-79 trucks. The first place our fellow brotheren are going to look for thier answers to all their problems. I know that is where I go because it is where I can talk to people who actually know these years of trucks, not just some random in the steering forum that my not know jack about 73-79's. Please let us keep helping one another out. Thanks.
Old Feb 16, 2005 | 06:11 AM
snyiper's Avatar
snyiper
I guess all the conversions are different so it would seem that year specific would be left in the proper years and not grouped together. I dunno but it is hard to search if you are not one of the elite, seems the search menu is always busy.
Glenn
Old Feb 16, 2005 | 08:28 PM
robtinalimon's Avatar
robtinalimon
Why convert? I have no problems with my new components of my highboy hydraulic assist steering. It took me an hour to swap in and I can turn my 33's
with a finger. But if you want to get rid of the parts let us, know.
Old Feb 16, 2005 | 08:39 PM
ozzy460's Avatar
ozzy460
how many power assist setups do you want? yea the work fine when they work. i got 2 complete setups here for grabs. everything works but the cyl puke oil all over.
Old Feb 17, 2005 | 12:35 AM
5.8LiterImportEater's Avatar
5.8LiterImportEater
I have the Ebay kit, and I love the truck since the installation. This thing rocks now, look at a past post in the 73-79 forum and you will see my review of it. really complete.
Chris
Old Feb 17, 2005 | 03:38 AM
Amtek's Avatar
Amtek
I purchased a kit from Scott Ibeling, it comes with a gearbox, pump, brackets for your particular engine, a mounting plate and hardware to fasten it all together. However you need to weld the plate in and modify your existing steering linkage to fit the new gearbox. You can also choose to modify your draglink or purchase a heavy duty adjustable one too. I have not finished my truck yet, but he said you could turn 40 inch tires on pavement with your pinky.
Just do a search for "Scott Ibeling" and a few posts will come up, one of them should have his phone number.
Old Feb 17, 2005 | 07:35 AM
stegmst's Avatar
stegmst
Bought mine from Ebay I have not recieved it yet. Should be here soon.
Old Feb 17, 2005 | 12:52 PM
fordfury469's Avatar
fordfury469
i made mine cost me three bucks.
Old Feb 17, 2005 | 12:57 PM
snyiper's Avatar
snyiper
Please do tell!!
Old Feb 17, 2005 | 02:20 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Best thing I ever did was go to the '79 steering box. Lots of junkyard trips and fabrication, but it worked. And 15 years ago, there wasn't a kit on Ebay
Did it without notching the crossmember too... but had a longer steering shaft and drag link, to boot...
Come to think of it, the power-assist control valve was totally unavailable at the time, or, it was $600 rebuilt.
Old Feb 17, 2005 | 02:21 PM
krewat's Avatar
krewat
Come to think of it, the power-assist control valve was totally unavailable at the time, or, it was $600 rebuilt. You guys are lucky they're available now!
Old Feb 17, 2005 | 03:52 PM
fordfury469
i used a 67 two wheel drive steering box. just basically got some scrap steel. welded my steering arm to make it longer then on my shaft from my u joint to the rag joint i made it longer so i could hook it up to the steering box where i mounted it in the 78 79 spot made a piece of flat steel and welded it in place in the frame rail drilled it attached the gear box to it. took alittle time but saved me alot of money in the long run. im gonna have to take pictures not the pretties thing ive ever saw but it works good never had anything go worng with it yet and it been like it for a few years.
