differential help
Old Jan 29, 2005 | 04:25 PM
jjenkins816's Avatar
jjenkins816
differential help
i'm having some trouble with my 74' T-bird 9" rear-end. i'm trying to get the axles shafts out and i can find the c-clip that i need to take for the axles shafts to come out. The housing has two parts the top that is held on with five or more bolts, and the problem part "the bottom of the housing" it has around ten or so nuts that hold it on. the top came off easily and the bottom is being a pain and it wont come off, is there a screw/pin or anything else that could be holding it on because it just wont get off, and with all the prying that i have done it will have to come off because the gasket is in bad shape and i'm just lost because it looks like it should just fall right off but it seems like it is hung up on something.
Old Jan 29, 2005 | 04:35 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
We are pleased you have chosen the best source for Fords!
Stick around someone will be by shortly to answer your question.
Enjoy FTE …..
See you on the boards.
Old Jan 29, 2005 | 08:01 PM
Chris_ce's Avatar
Chris_ce
No c-clips for the 9". Here is a link that will tell you have to remove the axles.
http://classicbroncos.com/rear_axle_removal.shtml
Old Jan 29, 2005 | 11:12 PM
SoCalDesertRider's Avatar
SoCalDesertRider
I've never seen a '74 T-Bird 9", but the way you describe it, it doesn't sound like a 9" Ford axle. What is this 'top' and 'bottom' part of the housing you are referring to? The reason I ask is there isn't any way you could get inside a 9" to see if there are C-clips on the ends of the shafts because you first have to pull the shafts to remove the 3rd member and removing the 3rd member is the only way to get inside the differential to see anything, since the rear housing cover is welded on.
If this is a 9" Ford axle and you've unbolted the 3rd member and can't get it to come out, but still haven't removed the axleshafts, that's likely the reason why you can't get it out- the axleshafts are still holding the 3rd member assembly in place!
To take the axles out of a 9", just remove the brake drums and brake hardware, remove the 4 bolts on each end of the axle tubes holding on the backing plates and bearing retainer plates, and slide the shafts out of the housing. Now you're free to remove the 3rd member housing .
Old Jan 30, 2005 | 02:25 AM
jjenkins816
third member
ok, once i pull the axles shafts out i should be able to remove the bottom part of the third member, does that sound like that how it done?
Old Jan 30, 2005 | 03:55 AM
SoCalDesertRider
Yes. Still not sure on the 'bottom' and 'top' parts you're talking about though. The 3rd member is all one piece and comes straight out the front of the axle housing.
