Tach Light Connection
Old Jan 29, 2005 | 03:27 PM
Linc66's Avatar
Linc66
Can anyone tell me which wire to hook the tach light wire to? the dash light would seem to make the most sense - is it the light blue wire near the top of the back of the instrument panel? the other place would be the light switch but which wire?
Thanks.
Old Jan 29, 2005 | 06:27 PM
Linc66's Avatar
Linc66
I got it. There was a bullet connection from the wire harness close to the light switch that worked. Although in doing that my dash light is not as strong. If I push on a spring on the light switch assembly, the dash light brightens significantly - I am assuming that it is just a connection or do I need to change or do something to the spring?
Thanks.
Old Jan 30, 2005 | 05:33 AM
jowilker's Avatar
jowilker
Those old bulbs dim with age, replace about 3 of them around the dash and it will make a huge difference.
John
Old Jan 30, 2005 | 05:43 AM
Linc66's Avatar
Linc66
Thanks, John. I'll do that.
