powerstroke need advaice
Old Jan 29, 2005 | 11:54 AM
mrwrench's Avatar
mrwrench
How much can I pay for a 1995 f250 with powerstroke problems (mayby bad injectors ) and bad E4OD transmission. Good shape 200 K miles.
Thanks
Old Jan 29, 2005 | 11:58 AM
Rancha9's Avatar
Rancha9
Not much... If it happens to be a problem that will require replacing a head or the whole motor, they're expensive. Re-man heads are 500-600 a pop, and a short block is about 3800. Just a set of injectors is 1300 or so.
Old Jan 29, 2005 | 07:30 PM
obmf2's Avatar
obmf2
My 1997 e4od lasted 142,000. Expect to spend at least $2000 w/o labor.
Old Jan 29, 2005 | 09:28 PM
tonydshinycar's Avatar
tonydshinycar
Sounds like a winner! If you buddy up at a trans shop(send food) you can usually strike up a deal under 2k. The drivability is not too bad ... failed-injectors, the wiring leading to them, and the mechanical fuel pump are common repairs easily done. However a blown motor will make it more valuable as parts!!!
meford
New Member Introductions
Jan 23, 2015 02:20 PM
429 f-100
34
Aug 22, 2011 09:11 AM
powerstroke1869
May 6, 2011 01:44 PM
yates99
23
May 30, 2007 08:40 PM
