Dual mass flywheel ???
Old Jan 29, 2005 | 08:53 AM
ckal704's Avatar
ckal704
Reading the Six-Speed clutch thread brought to mind a similar question: I have read in these forums that the dual-mass flywheel used on my 97 is likely to fail at some point and need to be replaced? Anyone have experience regarding the longevity of the OEM flywheel/clutch and what warning signs might I look for?
My truck has 74,500 miles on it now.
Thanks folks!
Old Jan 29, 2005 | 09:34 AM
01stroker's Avatar
01stroker
They go out at different miles. One thing to check is the rotational slack between the masses. It should be no more than 5/8". It usually starts to rattle and knock when going bad. We replaced a friends at about 130,000, the springs were about to come out. Most people replace it with a solid setup like Luk. You have to replace clutch and flywheel together if you go with a solid one. They are cheaper than OEM dual mass also! My friend loves his.
Old Jan 29, 2005 | 10:25 AM
Bigsilver95's Avatar
Bigsilver95
01stroker said it all, the luk or valeo is cheaper than a new dual mass setup. Mine went out at about 85-90K.
Old Jan 29, 2005 | 10:37 AM
ckal704's Avatar
ckal704
Thanks, fellas. Appreciate your help.
Old Jan 30, 2005 | 08:53 AM
jpm2591's Avatar
jpm2591
I have a question someone might be able to answer. I heard the F450 has a solid flywheel. Does anyone know if you could replace the dual mass setup with the F450 assembly. I was looking at the Luk and the price is still more then I want to pay.
Old Jan 30, 2005 | 09:10 AM
jpm2591's Avatar
jpm2591
HeyBigsilver95, was looking at your pics. How can you justify taking such a purdy truck through all that slop.
Old Jan 30, 2005 | 12:41 PM
Bigsilver95
Well, i was a stupid kid when i bought, started trashing it and then stopped rather quickly, now shes just a big pavement princess. Thanks for the compliments.
89 F-250 man
Jul 29, 2012 09:33 PM
BIG J82
Jan 11, 2012 07:53 AM
PAVEMENTMAN
16
Sep 9, 2009 06:07 PM
MustangMatt96GT
Feb 28, 2009 07:30 PM
quality1const
16
May 23, 2008 09:24 PM
