Sponsored by: Auxito
Neutral safety switch
Old Jan 29, 2005 | 12:35 AM
SirHailstone's Avatar
SirHailstone
I had a rather unpleasant suprise yesterday morning with my 04 Heritage. I got in it to go and turn the key - Nothing. Nada. I thought sure the battery went duff since it was only about 5 to 10 degrees F that morning, and checking to make sure I didn't dummy up the night before and leave a dome light on or something plugged into the power point - but I didn't. I turned on the headlights and they were bright, and they didn't dim when turning the key to start.
Hmmm .. I saw this happen once before on an E-350 cutaway (Ambulance) - moved the gear selector thru the gears a few times and it started. So I went up and down on the gear selector and tapped on the steering column a couple times. Then it started. Where is the neutral safety switch on the 04 Heritage? on the tranny or in the steering column?
Only 2200 miles so it's going to the dealer for repair.
Old Jan 29, 2005 | 07:45 AM
projectSHO89's Avatar
projectSHO89
The DTR is on the tranny.
Make certain that your PATS (if equipped) or any other alarm system (if equipped) is behaving properly.
If it's the DTR, try shifting into Neutral, then starting the truck. The switch is made to allow the starter to operate in both P and N.
Steve
bthr22
Aug 25, 2013 05:23 PM
toddspeed
15
Mar 23, 2013 06:16 PM
Ioki
17
May 24, 2012 10:21 PM
mmustafa
Feb 27, 2008 08:30 AM
jbirdsvt
Jul 18, 2005 10:37 PM
