Carb ID
Old Jan 28, 2005 | 10:09 PM
Colorado f250's Avatar
Colorado f250
Carb ID
I have a 83 F250 with a Holley carb. The numbers oin the air horn are 80179 and 1048. Does anyone know which carb this is and if it is worth rebuilding?
Old Jan 29, 2005 | 12:15 AM
kermmydog's Avatar
kermmydog
Are you sure there are not any letters with the number, My Holley book shows a 80169 then next is a 80180. Holley built carbs for Motorcraft and kits and parts are found under the Motorcraft # but it has numbers & letters, carbs have Holley on them. Just knowing alittle about these trucks I would guess it is a 4180, I'm assuming this is a 4 bbl.
Old Jan 29, 2005 | 06:44 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Colorado f250
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Enjoy FTE …..See you on the boards.
Old Jan 29, 2005 | 02:19 PM
Colorado f250
Thank you for the information. I check again and the 80179 and 1048 air ****. The 8 maybe a B but it looks the same and the 8 in 1048. Also on the body of the carb is 11031. It is a 2 bbl. Thank you for the help.
