Dana 70 hubs
Old Jan 28, 2005 | 08:18 PM
51dueller's Avatar
51dueller
Dana 70 hubs
Did the Dana 70B use the same dually axle hubs from '75-84? I need for find some for my '80 axle and need some possible doners. Did Chevy and Dodge use the same ones?
Old Jan 28, 2005 | 11:12 PM
SoCalDesertRider's Avatar
SoCalDesertRider
The Chevy hubs diameter are smaller than the Ford and Dodge hubs. All 3 have the same wheel bolt pattern though (8x6.5"). Ford pickup frames are wider than Chevy frames too, so the spring perch locations are different, unless you're talking about chassis-cab trucks, then the frames should be the same width. That's about the extent of what I know about that subject though...
