6 spd clutch
Old Jan 28, 2005 | 02:40 PM
tripod's Avatar
tripod
6 spd clutch
No prior warning-Little grinding when to 3&4.Clutch pedal stuck to floor,twice,pulled up by hand.Made it to house.At idle truck would go fwd w/clutch in.Now clutch stuck out.Slop in master cyl rod end (3/4"),Pedal travels about 1/2 travel.Soft and spongy.Help !!! thanx-tripod(newbie)
Old Jan 28, 2005 | 07:00 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..
See you on the boards.
Old Jan 28, 2005 | 08:34 PM
skuteman's Avatar
skuteman
..............Check your hydraulic slave cylinder . If it turns out that your clutch is out get out the plastic and just get it fixed . My clutch died when I came back out from a DC Burger at What A burger. Wouldn't even go into gear so I call the wrecker guy and we take a 40 mile ride to my dealer who is in a Town so small (Stowe Ford , Gordon , Texas) that you would never believe that Ford would have Dealership in this one horse Town . Best darn Ford people in the State of Texas . They are in an old RED Brick building about 100 years old . Very 1930's and makes you feel like that you're back in the Bonnie and Clyde era . Anyway , hope it ain't the Clutch , good luck , s.kuteman
Old Jan 28, 2005 | 09:13 PM
barebackjake's Avatar
barebackjake
sounds more like your pressure plate broke wedging the clutch ingaged, my niebors truck did that last week. more than likely time for a new clutch. how many miles?
Old Jan 28, 2005 | 10:49 PM
Kwikkordead's Avatar
Kwikkordead
Failed clutch hydraulics is the most likely cause. You can get the whole assembly pre-bled and ready to install at Ford for $140.00 last I heard.
Old Jan 29, 2005 | 06:11 AM
tripod's Avatar
tripod
88,000 miles and absolutely no warning.
Old Jan 29, 2005 | 07:53 AM
steveepp's Avatar
steveepp
Bad slave cyl.....I have had three replaced in my 2001
Old Jan 29, 2005 | 03:35 PM
tripod's Avatar
tripod
Thumbs up 6 SPD clutch-thanks
For helping the little guy.I will get the master cyl/slave cyl combo and change it.Great website.
Old Jan 29, 2005 | 03:47 PM
barebackjake
with 88k on it it could still be the clutch. when you push the pedal down slave travel should be 11mm are you getting that much?
Old Jan 30, 2005 | 06:42 AM
tripod's Avatar
tripod
When I push clutch pedal in,it only goes about 1 1/2-2 inches and spongy,dont go near all the way in.This happened after I had to pull clutch pedal out from floor 2 times.
